Hey guys! I recently got a DJI Phantom 4 Pro drone. Its an amazing drone, very easy to use and awesome video quality.
But I noticed that the camera is slightly panned to the right. Is there any way to fix this?
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/800930-dji-phantom-4-pro-camera-issue/
2 hours ago, Gerry said:
Have you tried gimbal auto-calibration from the DJI GO app menu?
Yep. Did not fix it.
In the DJI menu, there should be a way to manually offset the gimbal's balance.  When I had the Phantom 4, I had to do the same one time.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
Its not the roll whats the issue. The camera is slightly pointed to the right relative to the drone.
Look at how to camera is panned and compare it to the lines
That's what I mean, I remember having to adjust it manually.  Another thing you can try, if the gimbal calibration causes this while the drone is on a level surface try the calibration with the drone on an uneven surface.
