2 minutes ago, joshbot21 said:
Hey, what component of my PC should i upgrade first?
I have a GTX 750 graphics card and a AMD A10-7800 processor.
My question is should i upgrade my CPU, motherboard and ram first or my graphics card?
Cheers fam
Are you upgrading for better gaming performance?
Just now, joshbot21 said:
Yep, im not getting the performance and visuals i want in the games i play
I'm not familiar with that AMD processor so I wouldn't know if it would be a bottle neck for the new gtx 10 series. If gaming is the goal, than I would start with the gpu upgrade first. The only problem is that right now is probably the worst time to buy a gpu due to the gpu shortages. A lot of gpu's are over priced. If you can't wait for stocks to refill than start upgrade the cpu/mobo, but that won't have a direct impact on your gaming performance until you get a new gpu.
It's a bottleneck for even an RX560/GTX 1050.
Go for a used card, then you should upgrade your CPU. What's your budget? Also what is your PSU?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Ive got 196 USD and a 650W power supply, i was looking at a gtx 970
What model?
Full Specs
Helios EVO (Main):
Delta - Laptop
Silverstone Strider gold S series 650W
GTX 970 should do, preferably 980 and if you can even get one, 390/390X is so much better
Full Specs
Helios EVO (Main):
Delta - Laptop
Yeah, 390s are much more expensive here so i might buy the GTX 970. Should i definitely upgrade the graphics card before the CPU and Motherboard?
I think so, much as soon as you can PLEASE upgrade the CPU.
Full Specs
Helios EVO (Main):
Delta - Laptop
