First time that I build a new computer. I have installed windows on my ssd but faced problems so I had to reinstall it on my harddrive instead. The current problem I am facing is that it does not identifies my internet connection. I have tried everything form restarting my router to checking to see if the cables are alright. I even assigned my computer a static Ip address but so far nothing has worked :(.
https://linustechtips.com/topic/799609-need-help/
1st - You should really have Windows installed on your SSD, else, your SSD is pretty much useless. What was the problem that triggered the reinstall?
2nd - What do you mean by "it does not identifies my internet connection"?
- do you have a network connection?
- do you have a valid IP?
- can you see your PC from the router's side?
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/799609-need-help/#findComment-10058941
Are you using an ethernet cable or a wifi card?
https://linustechtips.com/topic/799609-need-help/#findComment-10059014
1) Yes
2)Yes
3)Idk
https://linustechtips.com/topic/799609-need-help/#findComment-10059387
cmd prompt as admin
netsh
winsock
reset
restart computer
plus the internet super screwy right now depending where you live
also try full reset on modem/router(hold reset button for 30seconds)
but have your isp account name and password ready to input into modem after reset
https://linustechtips.com/topic/799609-need-help/#findComment-10059466
