i7 has hyperthreading
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
i7 has hyperthreading and costs more
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
Is everyone misreading the post? This is the first i've heard of the 4760k but it sounds like they are both i7's to me. To answer the OP's question, if the specs are the same whereever you are seeing it, then they are most likely exactly as you said. therefore the best value is to get the 4760k and overclock it.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
I'm stupid, I forgot it was an i5, when I was looking on the page, thought it said i7
Ah, so you mean 4670k then :P
I thought it was wierd that intel would release a cpu with a lower clock speed. a 4780k with a 100mhz increase would proably be more common (as per the 2600k/2700k)
i7 has hyperthreading and 8mb of cache compared to the i5s 6mb and no hyperthreading.
