Specs
1080ti FE
7700k
16gb Ram
1080p monitor ( i know)
It seems like for my setup i am getting low fps. In games like battlefield one im only getting 60-70fps and in GTA 5 im getting around 60fps. I noticed that the GPU usage is around 99%. For benchmarks i have seen, it looks like i should be getting a lot more FPS. Anyone have any ideas?
https://linustechtips.com/topic/799149-1080ti-low-fps/
3 minutes ago, Atlas42 said:
Specs
1080ti FE
7700k
16gb Ram
V-Sync on? If it's not on, then you might want to reinstall the driver just to be sure. Since you put 7700K for your CPU, I assume you have OC it and should be getting more fps then what you are getting now.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/799149-1080ti-low-fps/#findComment-10053802
Using a high end graphics card on technology that doesn't push it to its limits (Not 1440p 144HZ or 4K 60hz) graphics cards tend to run at less than their best because they simply don't need to. I'm not sure why your GPU usage is around 99%, however. Try getting your hands on either a 4K monitor or 1440p 144hz and see if the story changes. (As in getting ~60fps in 4K 60hz or around 120-144 in 1440p)
Diamond 5 in League :)
https://linustechtips.com/topic/799149-1080ti-low-fps/#findComment-10053804
what is the cards clock speed at? Maybe it's thermal throttling for some reason?
Also, you should REALLY invest in a 1440p monitor with a gpu of that magnitude. At least make that a priority purchase when you can.
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
https://linustechtips.com/topic/799149-1080ti-low-fps/#findComment-10053993
GTA5 is just horribly CPU bound.
If you go up in resolution + higher graphics settings, you will notice that you will get higher visual fidelity without loss of average fps.
At least this is the case for my system. So I have cranked up every setting to max for GTA5 on my system with 1440P monitor.
https://linustechtips.com/topic/799149-1080ti-low-fps/#findComment-10054033
Did you max out every single graphic settings in both games?
https://linustechtips.com/topic/799149-1080ti-low-fps/#findComment-10054120
What exactly is the first line?
What is 100%, what is 76%, and what is 99%?
If you don't name them there, post the Screen of the Graphs themself :) Much more helpfull.
Lim1: Power indicates, your GPU is Powerlimited. Probably, depending on the Model, it has the stock Powerlimit of 250 Watt, and that's what it hits --> throttling (however, that will be just 1-2% performance difference maybe.
What are the Clock speeds?
https://linustechtips.com/topic/799149-1080ti-low-fps/#findComment-10054174
