I have built a system not so long ago and it seemed to work fairly well for the first couple of hours and then crashed.
I have tried reading multiple guides on solving issues but no solutions seemed to work, the system crashed after 5 min to 2 hours after booting and under different load.
If anyone can help here is my build https://pcpartpicker.com/list/GjHjqk
Thanks in advance
https://linustechtips.com/topic/798561-help/
20 hours ago, 3keyman said:
BSOD
what is the BSOD error code? if it just "blinks" before shutting down, film it on your smartphone and find the BSOD information that way
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/798561-help/#findComment-10060164
