Hello!!
I need help in choosing a laptop... I'm searching for a laptop to replace my gaming rig in lan parties and travel.
My gaming rig is pretty high spec: https://pcpartpicker.com/list/QVKfZ8
I already spent a lot of money on it, so spending the same amount on a laptop isn't an option.
I'm looking more into the 2300 / 2500$ CAD bracket maximum.
In USD, that's around 1700 to 1900 approximately.
If there is no shipping in Canada I have my own ways ;)
What I am looking for is GTX 1060 performance. This will stay a secondary PC so I don't need it too powerful.
The only specification I have is that it has to have an SSD and HDD and be a 17" if possible.
Bonus points if it has thin bezels :D
I looked into those two:
http://www.dell.com/ca/p/alienware-17-laptop/pd?oc=na174_fkblwk2_h8e&model_id=alienware-17-laptop#overrides=
https://www.newegg.ca/Product/Product.aspx?Item=N82E16834233201&cm_re=gigabyte_laptop-_-34-233-201-_-Product
Otherwise I love MSI's styling, but they have so many models I can't seem to find what I want.....
Maybe some you you have a recommendation for me??
https://linustechtips.com/topic/798370-need-help-choosing-a-laptop/
Check the thread linked in my signature.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Wow that helped a lot!!!
Decided to go with the MSI Gt72VR. What's funny is that it's cheaper on the us site than Canadian one hahahahaha
Even with the money converted, it's 300$ less:
https://www.amazon.com/XOTIC-Dominator-WideView-i7-7700HQ-GTX1060/dp/B06XC13Q5C/ref=sr_1_1?ie=UTF8&qid=1498386540&sr=8-1-spons&keywords=msi%2Bgt72vr&th=1
https://www.amazon.ca/GT72VR-Dominator-i7-7700HQ-GeForce-Windows/dp/B06XC13Q5C/ref=sr_1_10?ie=UTF8&qid=1498386605&sr=8-10&keywords=gt72vr
And it's the exact same item and bundle!!!!!
I will think about it a little bit and order from us site to get the discount :P
6 minutes ago, Teddy07 said:
xps 15 is the laptop I recommend to anyone with a higher budget. Very good one.
Yeah I sold this laptop twice back when I was Dell partner and having it in my hand: DAMN it's pretty and fast :D
Problem is, the highest configuration is only a 1050, so forget about gaming on this thing!! I find it more suited for programmers or heavy office workers than gamer. The screen is gorgeous though :x
NEVER get a 4k panel on this size of screen. Yes there is a difference, but always running windows in 200% scaling you can run into trouble in some applications. the extra resolution is also more power hungry on the battery. I always sold the 1080p version. Would be awesome if they had a 1440p model ^^"
uhhhh you should get this instead.
http://www.hidevolution.com/evoc-p670hs-g-custom-built-gaming-laptop-w-nvidia-gtx-1070-w-g-sync.html
buy all the ram and storage yourself and you'll have a sick system.
1060 for that much money is a rip off
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
by buying all ram and storage, I'm still falling over budget sadly.... it is a sick system though.
tons of IO it would seem, screen is G-sync IPS pannel, not sure if 60Hz though...
I would stay with the MSI one because I have good experience with their customer experience in the past and it's a sick bundle :P
did you notice that it's a 1070 laptop? there is a 1060 version.
http://www.hidevolution.com/evoc-p670hp6-g-custom-built-gaming-laptop-w-nvidia-gtx-1060-w-g-sync.html
the screen is 75hz.
but the gt73vr is good as well.
Laptop Main
