1 minute ago, saibalroop said:
My 860K reaches 110C with an aftermarket cooler.
Well, that relaxes my concern for my father's 860K idling at 70oC, although 110oC for any CPU does seem rather ridiculous especially considering you are using an aftermarket CPU cooler. I
f anything that thing is probably thermal throttling worse than a 2013 MacBook...
May I ask, did you correctly install of the cooler (Made certain your followed the instructions for the right socket.), did you make sure that you removed of the plastic wrap on the bottom of the CPU cooler & did you actually apply thermal compound?
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/798195-cpu-overheating/#findComment-10043969
1 minute ago, Ststse said:
Will it in the future damage my cpu?
definitely . If the reported temps are correct , that is above the max operating temperature for that chip .
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/798195-cpu-overheating/#findComment-10043974
2 hours ago, Ststse said:
Is a maximum temp of 84c too hot for my i5 6500, while playing battefield 1 for long periods of time? I have the stock heatsink. Will this damage my cpu? I've already reapplied thermal paste and made sure I mounted the heatsink correctly.
If anything you will start throttling up to a point where the pc shuts down.
No. If anything it will shutdown more often.
Cheap solution: Hyper 212 EVO, MX4 Thermal paste.
https://linustechtips.com/topic/798195-cpu-overheating/#findComment-10044436
