What is your setup? GPUs? CPUs? ASICs?
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/79809-bitcoin-help/#findComment-1094482
well i have to look first
If you have to look up what gpu you have. You shouldn't even try :(
Bitcoin mining is mostly not worth it with the electricity cost and the fact that it gonna be extremely slow. The ASIC bitcoin miners have taken over gpu's
I'm the Forum Owl
*Who*
https://linustechtips.com/topic/79809-bitcoin-help/#findComment-1094500
I'll say that it will take years for you to mine 1 coin = don't do it.
https://linustechtips.com/topic/79809-bitcoin-help/#findComment-1094514
yeah but its not mine cuz mine is broke my brother broke it and he hasent payd me yet! :/ and the pc att my mom's place "wich is my brothers" is the one i use for now
Unless that pc has triple 7970's (Or quad)
your not gonna make a thing
I'm the Forum Owl
*Who*
https://linustechtips.com/topic/79809-bitcoin-help/#findComment-1094518
