Front panel pin connectors
Go to solution Solved by RadiatingLight,
doesn't matter
when you click the power button, it just connects the two, so it can go either way.
So I referenced my manual and I know where to put the pins but I would like to know which side the power switch connectors go into, the negative and positive connectors. Because there's no positive or negative indicators on the manual like they are on the actual connectors.
Power switch positive and negative not labeled here
https://linustechtips.com/topic/797639-front-panel-pin-connectors/
doesn't matter
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
The only ones that matter which direction it goes are the LEDs.
Otherwise the Power and Reset buttons are switches, they complete a connection so it doesn't matter which way they go.
