That depends, do you edit videos professionally?
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035015
Just now, NCIX Lampy said:
No, but I figure since a ton of people have it and it's a one time buy, why not
I really like it. I use iMovie more though.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035022
Really? Isn't that a free app?
$30.
Final Cut Pro is $400.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035038
8 minutes ago, JDE said:
$30
iMovie is free unless you had a really old Mac
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035088
LIKE I DO! MacBook Pro 13" 2009
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035091
lol
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035094
Just now, Lethalmonk said:
imovie doesnt take mp4 or something.
I'm pretty sure it does
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035100
I wouldnt get it unless you NEED it.
It does, and it exports in MP4.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035104
There are better ways to waste 400 dollars.If your going to waste that much money at least do something dra
matic
My life
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035105
1 minute ago, NCIX Lampy said:
Source? That seems pretty extreme
it takes mp4 lol, dont listen to him.
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035123
No source, takes MP4/H. 264
IT EXPORTS IN H. 264!
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035134
OP so what do you do when you make videos?
iMove is a linear editor with some basic features like picture in picture.
Do you need multichannel video and audio? If the answer is no, just use iMovie!
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035159
1 hour ago, Lethalmonk said:
I can do it right now on my MacBook Pro
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035513
It's absolutely pathetic that any video editor wouldn't be able to import a common format ... kind of defeats the purpose.  But, I have seen it myself, be it video or audio, I know of a few programs that can't open things they definitely should be able to.
3 hours ago, Lethalmonk said:
Reading that thread, it appears mp4 is sort of a container like mkv that can contain many different codecs, so while one mp4 might work perfectly another may not since they actually are fundamentally different internally and just share a name.  Ie, you can both be correct.
https://linustechtips.com/topic/797322-final-cut-pro/#findComment-10035843
