Water Cooler maintenance?
Solved by LooneyJuice,
Holy f***ing shit!
Well, here's an easy one. How about blowing out the radiator? It's the simplest thing he could do and will probably net him an easy few degrees C just from that. Of course, while he's at it, he can clean up the whole system
. That's the easiest bits. Radiators clogged with dust perform terribly. If that doesn't do it, then you move on to fresh thermal paste. And if that doesn't do it either, well, then, depending on how old the AIO is, it could either be liquid permeation/evaporation or a faulty pump. You can only really tell by reported RPMs from the pump header it's plugged into by checking out HWmonitor etc.
Best of luck.
