So I just noticed a strange issue in Overwatch. In all my other games my 960m runs at its full speed of 1202MHz. In Overwatch though it runs at a constant 540MHz. Oddly, performance doesn't seem to be effected by the lower clock speed as I am able to get a constant 60fps at 1080p, high settings. Why would my GPU not be running at full speed in Overwatch? Any tricks to get it to run at full speed and maybe get up to Ultra settings or higher?
https://linustechtips.com/topic/796864-low-gpu-clocks-in-overwatch/
You might have on the V-Sync in Overwatch. It will go up to your monitor accepted Hz which I assume is 60Hz and that will not use much GPU power to generate.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
I use VSync on most of my games to prevent screen tearing. I'm confused as to why it is only running my GPU at 540MHz regardless of what I do.
4 minutes ago, Squirrel724 said:
Even pushing it up to epic settings I still only get 540MHz getting about 45fps.
Hmmm. If you are not getting the full 60fps in overwatch then that is weird. At 1st I thought because overwatch doesn't uses your GPU too much and thus the low MHz but if you are still not getting 60fps on it, then that should not be the case. Maybe you can take a look in the settings or maybe even reinstall overwatch just to see if it makes any different. I don't play overwatch so not really sure what's wrong with it. Sorry.
What's CPU usage and GPU usage like?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
CPU hovers between 10 and 50% depending on what is going on. On Epic settings the gpu is at 95-99% but again at less than half the max clock speed (540MHz vs 1202MHz). In every other game I own my gpu runs at the full 1202MHz.
System is a 6700HQ with a 960m. No thermal issue as both run under 78C.
Is the laptop plugged in?
Also try setting windows power plan to high performance.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
21 minutes ago, Squirrel724 said:
Laptop is plugged in and on high performance.
Only on Overwatch right?
What happens if you turn off v sync?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
