So I put the x4 630 in the PC and it ran pretty solid! The only thing is the games are still having some studder. Would have something to do with the drive? I have the 1TB Green HDD it came with. It only runs at 5400RPM, is that causing it to bottleneck?
CPU: AMD - Athlon II X4 630 2.8GHz Quad-Core OEM/Tray Processor  ($18.00)
Memory: G.Skill - Ares Series 8GB (2 x 4GB) DDR3-1866 Memory  ($0.00)
Storage: Western Digital - 1TB 3.5" 7200RPM Internal Hard Drive  ($0.00)
Video Card: EVGA - GeForce GTX 660 Ti 2GB Video Card
Power Supply: Rosewill - 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($50.00)
Total: $68.00
Generated by PCPartPicker 2017-06-20 14:55 EDT-0400
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
https://linustechtips.com/topic/796126-project-pc/
what games?
probably running out of vram or general raw power is simply not enough.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/796126-project-pc/#findComment-10021911
1 hour ago, 19_blackie_73 said:
what games?
I have 8GB of RAM running on it. Just L4D2 and TF2. I'm running 60fps but sometimes it goes to 45fps
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/796126-project-pc/#findComment-10022303
Vram is on the gpu
Use afterburner to determine what's happening
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/796126-project-pc/#findComment-10024962
