https://pcpartpicker.com/list/c3fCWX
This is my current PC build. I'm going to use this almost entirely for gaming. My budget is $1500. Are there any places I cut down on money so I can possibly buy a better keyboard and mouse or another monitor? Also, is there any way to check if the computer parts are compatible in size, or does pcpartpicker already show size compatibility? Plz help.
https://linustechtips.com/topic/795716-first-build/
You don't need a $200 motherboard so you can save money there easily.
A 120mm AIO isn't really worth it either, a decent air cooler will perform around the same.
Yes it's compatible, PCP shows any issues if they aren't compatible parts.
https://linustechtips.com/topic/795716-first-build/#findComment-10016869
If you must go with an aio, get a 240mm. otherwise go with some noctua or anything like that.
200 dollar motherboard is a bit much.
1080 is also a bit overkill, unless you want to game at 4k or something.
Comic sans is best font
-me to my graphic design teacher 6 seconds before I got kicked out of the classroom
https://linustechtips.com/topic/795716-first-build/#findComment-10016884
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($327.89 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.99 @ Amazon)
Motherboard: Gigabyte - GA-Z270XP-SLI ATX LGA1151 Motherboard  ($96.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($114.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($87.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Zotac - GeForce GTX 1080 8GB AMP! Edition Video Card  ($499.99 @ B&H)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case  ($129.99 @ Newegg)
Power Supply: Corsair - CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1401.14
Generated by PCPartPicker 2017-06-19 18:35 EDT-0400
You could also go to a 1600 and save $150, go to a 1070 and save $100, or both (to have more money to put towards monitor an peripherals).
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/795716-first-build/#findComment-10016923
Total: $1401.14
What the flip is the PSU?! I better go with SeaSonic G 550W
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/795716-first-build/#findComment-10019936
G series is also more expensive though.
CXM is a good psu. It's tier 3 on the tier list and would be tier 2 if it wasn't for the sleeve bearing fan.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/795716-first-build/#findComment-10020372
You can absolutely 100% get a better a PSU for $80. I'm almost certain the EVGA 650W GQ is $80. That Corsair CXM unit is absolute trash. The new grey label CXM units are alright, definitely better than the old green label units(which again, are absolute trash).
OP - You'll need to tell us what monitor(s) you're actually using with this system?
Also what games will you be playing, and will you be using the system for anything other than gaming?
Will you overclock?
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/795716-first-build/#findComment-10020484
The CXM series is good enough but he doesn't need 750W for this build.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/795716-first-build/#findComment-10020558
What it is $52 in us
My head on 2019 :
https://linustechtips.com/topic/795716-first-build/#findComment-10020755
Will you overclock?
I 'twas kinda lazy and didn't feel like changing it out :P
I also didn't notice the MIR tho.
If you compare a CXM grey sticker into and a GQ I would grade them about the same on electrical performance, the only reason I would give it to the GQ is because of the sleeve bearing fan on the CXM.
Yes the GQ is better. No it's not by that much.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/795716-first-build/#findComment-10021383
GQ is an entire tier above the new CXM units, on the thread here. Or;
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=454
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=486
The exact models we're comparing. Ignore value since they're the same price. That's a score of 29/30 for the 650W GQ and a score of 27/30 for the CXM unit. The EVGA GQ unit is objectively better, and is better rated. Whether it's by much or not is pretty irrelevant since they're the same price.
https://linustechtips.com/topic/795716-first-build/#findComment-10021920
I said electrical performance, not overall. If we compare them based on electrical performance, I would rate them similarily (GQ has better voltage regulation but the CXM has much better ripple).
Yes, if you factor in build quality GQ is better. But I said electrical performance.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/795716-first-build/#findComment-10021999
Also my recommended PsU is $56 after some discounts (in the signature)!
My head on 2019 :
https://linustechtips.com/topic/795716-first-build/#findComment-10036277
