My phone has been acting weird recently, the charger has been going in and out as in sometimes it works and sometimes it doesn't. I've used others and the same thing happens. After time it creates a black residue and the charger no longer will work. Most of it can be wiped off and it sort of works, but it keeps coming back. I will upload a picture later when it comes back. Also my apple earbuds that connect through the lightning connector don't work half the time and they work in every other iPhone 7 I have tested them with. Please help...
https://linustechtips.com/topic/795680-iphone-7-problems-again/
Try not to use 3rd party accessory.
And take it to the apple store. Took some photos of your phone malfunctioning.
I think they will sort it out for you.
If it is not broken, let's fix till it is.
https://linustechtips.com/topic/795680-iphone-7-problems-again/#findComment-10026747
  • 2 weeks later...
I had to use a different cable cuz it already fried my first one
https://linustechtips.com/topic/795680-iphone-7-problems-again/#findComment-10077425
Haha...so true...
I mean..he clearly has a short or an overvoltage, and it's not that he asked a dumb question.  it's his horrible toxic attitude.
I mean, something fries...you're going to keep using it?
What would you be posting if your entire house or apartment burned down instead of you getting off lucky?
Now take it to an apple store and get it replaced.
https://linustechtips.com/topic/795680-iphone-7-problems-again/#findComment-10078840
