It could be some form of copy protection.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/795543-help-with-halo-disc/#findComment-10015108
or a scratched disc.
i know that there is a form of copy protection existing where they added "bad sectors" on purpose but i don't know if halo has it ... i was able to copy my own halo disc just fine. (halo 1 that is - did not try halo 2 because i lost the key anyways)
https://linustechtips.com/topic/795543-help-with-halo-disc/#findComment-10015143
Im copying the original halo disk also the disk is in the same condition as last time i did it. Also i think your right because it failed to read over 500 sectors
https://linustechtips.com/topic/795543-help-with-halo-disc/#findComment-10015176
try again and see if it still has problems ... if it has, it's probably copy protection ...
to combat this you can disable hardware/software retry in imgburn so it just skips over the "damaged" sectors and does not waste hours on retries.
https://linustechtips.com/topic/795543-help-with-halo-disc/#findComment-10015197
Ok. Thanks. I just was wondering because i dont remember it doing it last time (But i really wasnt paying attention)
https://linustechtips.com/topic/795543-help-with-halo-disc/#findComment-10015202
