So i was thinking of getting 5 new silent wings 3 pwm fans and rgb lightning, fans would cost me around 100 euros and rgb around from 10-50 euros + shipping (havent decided what to get for rgb), on the other hand i could get a new case with rgb, better fans and the looks, for the case im willing to spend around 200-250 max, if i get one, because i will still need 2 fans for my watercooler. What should i do? And which case should i get, if the answer is possitive? (A fancy one of course) My current case is RVX01 from Raven by Silverstone, its not bad, but smallish for my setup, i got 1080`s in sli and i7 5820k if i remember correctly.
https://linustechtips.com/topic/794637-case-or-case-fans/
Just now, Tibbles said:
You're better off prioritizing the case first, then fans, then whatever else cosmetic.
I know that was my main question, rgb is in the back, the main question was, should i change the case or leave the one i got right now and replace all the fans.
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004643
I'd replace the fans first then, noctua have excellent fans (if you can stand their colour scheme), be-quiet also have some good fans with low noise.
I will be replacing the fans one way or another, i asked whether i should change the case too, and in that case i would not need to change some of the fans (only for the watercooler), because the case would probably come with better fans as it would cost more.
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004682
personally I would just save the money for later on :) there's no difference if you upgrade the case or get RGB fans (and if there was, your temps will be lowered by 1-2c)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004733
Am doing so, but the fans could be used in my next build anyway, and the main point is to make this system quieter.
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004741
Yea, i guess there isnt real point of rgb for now.
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004744
determine what is making the most noise.
CPU cooler -> get better CPU fans or small downgrade to large aircooler
GPU -> screwed outta luck
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004747
I mean all 5 of those fans are making quiet a noise, when doing stuff that doesnt requier gpus (2 for radiator and 3 for case), i will just change those, its not much, 100 euros for all of them and they can be used later on, no?
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004758
That's a good looking case ^^
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004769
I say get a new case, bring some new life to your system.
How about the Corsair Crystal 570X
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/794637-case-or-case-fans/#findComment-10004915
