Hy to all of you reading this. Im currently thinking about building my own 3D printer... anyone with experience want to help me?
I will attach a file with the electronic gear I plan to use.
The main problem im facing right now is the frame.... there are no premade solutions on the internet so I was wondering what would be the best solution for making one myself.
links 3d printer.docx
https://linustechtips.com/topic/794475-building-diy-3d-printer/
well i wanted to build it myself with the components i selected so i can easily upgrade it... it is also mainly meant as a learning process so i get to know some eletronics.
19 hours ago, Hackentosher said:
Prusa i3 frame
Is it a good frame and can you buy it seperate? Like without all of the electronics?
Btw any of you have some advice on my electrical and mechanical components?
https://linustechtips.com/topic/794475-building-diy-3d-printer/#findComment-10007913
some kid in my engineering class built the frame out of 2x4s (wood) and metal brackets
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/794475-building-diy-3d-printer/#findComment-10014947
31 minutes ago, Baptiste said:
do you have some pictures?
i dont and im no longer in contact in the individual. im sorry
https://linustechtips.com/topic/794475-building-diy-3d-printer/#findComment-10022830
