Hard Drive "Glitch"
Go to solution Solved by Fluffy Bunny,
I fixed the drive. It was software preventing it from being a regular disk, I just completely wiped the drive then added a new volume in computer management. Thanks for the help.
Im getting a 1TB hard drive ready for my friend. Its a WD Caviar green with 7200RPM and 30mb cache.
The issue is that this hard drive only starts spinning if its using an external HDD enclosure power connector , not any ordinary PC power supply. I tried changing the power connectors and using an eraser to clean the ports and this does not fix the issue.
Any Ideas on what might be wrong?
Note: this HDD is from an external HDD drive and I also have a 2TB hard drive that is also from one. The 2TB one is my current second hard drive I use and it works fine with my CX600.
https://linustechtips.com/topic/794414-hard-drive-glitch/
Are you attaching power and data to the drive?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/794414-hard-drive-glitch/#findComment-10002379
4 minutes ago, Bill Nye The Nazi Spy said:
i was thinking it may be the way the hard drive is formated to be a hard disk. As the drive splits into two when you plug it into the regular power supply. My Book and WD
No matter how the driveis formatted, it should spin up and be detected by the BIOS and the OS (Even if it can't mount the partitions, it'll see the DRIVE when you look at it in Computer Management)
https://linustechtips.com/topic/794414-hard-drive-glitch/#findComment-10002498
