Planned System Build for my non-RGB future
16 minutes ago, CHILDISH_K1LL3R said:I see... so it could but at random times. Am I correct? if so, then what would be the average at high?
15 minutes ago, Damascus said:Just google the games and the GPU together and check the results...
Your frames will also depend on what settings you're using. Anti-aliasing (i.e. SMAA, SSAA, etc.) and tessellation, for example, can be pretty demanding on a gpu. so frames won't be as high with features like that enabled. It depends on the game and your graphics card as to what graphics settings are available to you, but you can still change the amount of AA in most games graphics settings. (or turn it off). I don't think a 1080 is overkill in your situation. It might be for some of those games, but in general, i think you're right where you need to be
