1 minute ago, afyeung said:
Does the 980Ti reference use copper on the baseplate? I want to use liquid metal with it which won't work with aluminum
dont be stupid just google it
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Don't be stupid and believe that someone who's had much more experience than you on LTT hasn't already tried looking things up.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
that was constructive
OP, it does not appear so
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
I know I was joking around
Could be nickel plated but I doubt it. Temps aren't that bad but I have to crank up the fans a lot higher than I'd like since it's summer. I'll repaste with something of quality if things get worse.
Thanks for clearing that up. No hard feelings
Oh I know I learned it from a group of people that a game them and I play
Yeah, I changed the paste on my 980 Ti (Though I have the windforce Gaming OC) and sanded the base of the heatsink (nickplated copper) and saw a solid 10C drop.
I'm almost certain it's nickel plated copper for the reference card. I might be wrong though.
