Looking for 7700k Delidding Help
Solved by Majestic,
14 minutes ago, Somnax said:This is helpful. What should I replace the thermal paste with after though?
Use a delidding tool for one, that der8auer kit is probably only really available in EU since he's shipping them via Caseking.de
Use something like Coollabaratory Liquid Ultra or Grizzly Conductonaut. Note that it's highly conductive, including electricity. Any spillage kills whatever it shorts.
Use either masking tape when applying, or coat the smd's next to the CPU with some paint or latex
