Well, I have a Corsair Carbide SPEC-Alpha and I plan to buy an i7-7700K paired with a Deepcool Lucifer V2 (in about 6M-1Y), but it's 1,2 cm. longer than my case width, according to both manufacturers' websites. Would it be "alright"? Or should I look for another CPU cooler?
There aren't much brands here (in Argentina) and I really love that Deepcool.
By the way, case "modding" is an option for me, but I'll appreciate all your advices/suggestions.
*** Pictures added.
https://linustechtips.com/topic/792362-cpu-cooler-compatibility/
12mm would be more than just a "few tiny holes" it would mean cutting out the entire huge rectangle for the fins and fan to stick through.
Either buy a new case or buy a different cooler because it will look horrible if you try to mod that to fit.
Even leaving the side panel off would probably look 10x better.
https://linustechtips.com/topic/792362-cpu-cooler-compatibility/#findComment-9979680
But there aren't many CPU coolers that could both fit in my budget and provide me good value/OC room/looks... I found just 3 brands between my price point:
1- Deepcool
2- Zalman
3- Cooler Master.
https://linustechtips.com/topic/792362-cpu-cooler-compatibility/#findComment-9979704
