You seem to already be connecting both required cables on the HDD, the power one and the sata one so you don't need to connect any thing else.
The first cable is a female molex which hardly has any usage aside fans nowadays or if you use adapters to use it as a sata power up or pci-e power up.
The second cable is a CPU one? I don't really tell if so or if pci-e from the shoot but if you already connected your CPU power up on the motherboard and that one is being an "extra" you don't have to connect it anywhere.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/792244-help/#findComment-9978097
The first cable is a molex and is not used for much nowadays, the cpu goes int to top of your mobo close to the cpu
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/792244-help/#findComment-9978099
1st picture looks like Molex it will power a peripheral of some kind.
2nd looks like 8 pin CPU or PCIe. They should be marked somewhere?
Btw you don't need to use all the cables on a PSU.
https://linustechtips.com/topic/792244-help/#findComment-9978102
yeah
Elemental
Laptops
https://linustechtips.com/topic/792244-help/#findComment-9978117
