Parts:
Bitfenix Phenom
Corsair H105 cooler
Corsair AX760
Corsair Vengance 2x 8gb 3200 ddr4
AMD Ryzen 7 1700
Asus GTX 1060 Turbo
MSI B350 Mortar mATX
Wanted to get some opinions on my first computer which I intend to use for engineering work as well as gaming. But I also just have one question regarding fan placement. My rear fan is exhaust, my bottom fan is intake and my top radiator fans are intake. My only concern is that due to my gpu being a reference card (which run hotter due to their construction) is it bad to be blowing warm are from radiator onto my gpu? If anyone has helpful advice on the best placement of these fans it would much appreciated. Thanks
https://linustechtips.com/topic/792216-first-pc/
what temps you getting on your GPU while the entire systems under load, if they are under 70C then don't worry about them  it's fine, if not turn the radiator fans into outputs and all others into intakes
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/792216-first-pc/#findComment-9977828
