I would go with "don't do it" by Sea[riously]sonic.
850W should be enough, but 1000W would keep it safer. I'd recommend going rackmount, if you can, with 1000W redundant PSU's.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9974969
  Hide contents
cool, thank you, what if i were to jump to 6? what size psu then.
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9974973
At this point, I'd seriously consider the Se[riously]sonic.
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9974975
what are you even saying?
To not do it. Geforce doesn't have the mining power that Radeon has and you might be wasting more power than the coins are worth.
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9974985
well im already mining with a few nvidia cards and they are going strong so no, im not wasting more power, where are you getting your information
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9974991
It's up to you. You'd best be served by going to a calculator and getting a rough estimate.
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9974995
I'll just chime in here. I don't know much about mining, but everything I've heard (even on WAN Show) indicates to me that Radeon cards are better for mining.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9975000
better yes, but nvidia isnt bad, its like an old car vs new for gas mileage, if you have the old one it works great but its helps to have the efficient one, in the current time amd cards are jacked up in price so im going nvidia
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9975003
970 will use up to 180 watts.  Assume maybe around 160 watts per card, of which maybe 20-50 watts would be from the pci-e slot.
Be careful how you power so many cards from the motherboard, you may overload the 24 pin atx connector with so many cards. (unless you're using pci-e extender cables with their own molex power connector so you won't take power from slots)
So basically 5 x 180 watts = 900 watts ... 100 watts for mb+cpu+ram ... i'd go for a 1050-1200w power supply just to be safe.
https://linustechtips.com/topic/791983-psu-question-for-mining/#findComment-9976089
