so in the last few weeks i was thinking about getting a new data plan i looked it up and i found 3 data plans but and don't know which one to choose there is one which gives me 100GB per month the speed is 1 Mbps down 256 Kbps up and the throttling speed 512 Kbps for 100 EGP (i live in Egypt btw thats why the plans are soooo bad) the other one is 150Gb per month 2 Mbps down 496 Kbps for 140 with 512Kbps throttling and the other plan is an unlimited one 1Mbps down 256 up for 140 Egp and the 40 egp will be from my pocket so which one do you recommend for me. I use the internet for online gaming on my ps4 for 2-3 hours but way more in the days of watching youtube for 2-3 hours a day on 360p
https://linustechtips.com/topic/791938-help-with-data-plans/
It sounds like the middle option is better bang for the buck than the latter option. And due to speed, I wouldnt get the first one.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/791938-help-with-data-plans/#findComment-9974358
I would get the 150GB plan because of the higher speeds.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/791938-help-with-data-plans/#findComment-9974362
but its limited do you think it will be enough for what i use???
https://linustechtips.com/topic/791938-help-with-data-plans/#findComment-9974407
At those speeds it should be fine.
Main System: Phobos
https://linustechtips.com/topic/791938-help-with-data-plans/#findComment-9974439
2 minutes ago, Markos76 said:
i wonder is it 150GB of download and 150GB of upload or 150gb for upload and download
It's probably a combined 150GB up/down limit.
Main System: Phobos
https://linustechtips.com/topic/791938-help-with-data-plans/#findComment-9974639
