How does this build look? All help is welcomed and appreciated!
 https://pcpartpicker.com/list/tG9TgL
Primarily gaming and some streaming.
$2000 budget  (pieces over time)
**EDIT***
PSU: Evga supernova g2 650w
(I'm stupid)
New ssd to m.2 (thank you minibois)
https://pcpartpicker.com/list/RYv6bj
https://linustechtips.com/topic/791797-first-build/
The cooler already comes with thermal paste.
You're welcome, I saved you 4,75 USD!
/s
Also, your memory is not on the Asus QVL: http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/STRIX_Z270H_GAMING/STRIX_Z270H_GAMING_memory_QVL.pdf
Which means you're running a chance it wont operate at full speeds.
It's good memory and 16GB is nice to start out with, but just take into account you're taking risk with it.
Otherwise it looks good, if I were you I would consider an M.2 SSD though, like the 960 EVO. It's a bit more, but is a lot faster too (SATA SSD's are fast already, but M.2 is like ultra fast and only about 35 USD more).
https://linustechtips.com/topic/791797-first-build/#findComment-9972774
/s
and PSU is bad
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
https://linustechtips.com/topic/791797-first-build/#findComment-9972784
1 minute ago, domandric034 said:
and PSU is bad
It's tier 4:
Hardly bad, but yeah not the greatest. OP could consider the Corsair RMX or EVGA G3 PSU's.
https://linustechtips.com/topic/791797-first-build/#findComment-9972799
/s
What memory should I get? (My phone won't click on the link)
https://linustechtips.com/topic/791797-first-build/#findComment-9972825
It's quite an extensive list of memory xD but you're looking for 2x8GB of memory, running at 3000MHz (or more)?
Any brands you specifically were looking for? Do looks matter or..?
Either way, I will look for some compatible sets. Keep in mind not all sets may be, as, freely available in all regions.
https://linustechtips.com/topic/791797-first-build/#findComment-9972841
Just black aesthetic if you could. I live in the US California. I appreciate the help so much!
https://linustechtips.com/topic/791797-first-build/#findComment-9972847
Confirmed 3200MHz:
https://pcpartpicker.com/product/4n648d/gskill-tridentz-series-16gb-2-x-8gb-ddr4-3200-memory-f4-3200c16d-16gtzkw (Black and white look)
https://pcpartpicker.com/product/x6rcCJ/gskill-memory-f43200c15d16gvk
https://pcpartpicker.com/product/sykwrH/gskill-memory-f43200c16d16gtzb (this one has no black aesthetic though)
https://pcpartpicker.com/product/Cf98TW/gskill-memory-f43200c16d16gvkb
Most interesting one:
https://pcpartpicker.com/product/qGqbt6/gskill-memory-f43200c16d16gvgb
These were the most interesting ones I could find, but even the last one mentioned is twenty dollars more just for 200MHz more and it being confirmed to work at that frequency.
That list is only a list of stuff confirmed to work at whatever frequency, it could just be they have not tested the set you chose.
https://linustechtips.com/topic/791797-first-build/#findComment-9972889
3 minutes ago, Minibois said:
Confirmed 3200MHz:
I'm thinking they just haven't tested it yet. I might go with that last one though just to be safe. I appreciate your help so much. Do you see anything else wrong with my build?
https://linustechtips.com/topic/791797-first-build/#findComment-9972909
Looking very good now :)
By the way, I just want to mention Ryzen 7 to you.  They have, for pretty much the same price of that i7, twice the threads, but less per core performance (which is what you want in gaming). the i7 seems like a good idea for you, but I just want you to know there are more options.
Also, definitely consider making a build log: https://linustechtips.com/main/forum/3-build-logs/
This is a great way to have some mini reviews on all the components and generally is just fun to do.
https://linustechtips.com/topic/791797-first-build/#findComment-9972945
You have helped me so much. I really appreciate it! I will definitely check out the build logs and the ryzen 7. You sir are the real MVP!
https://linustechtips.com/topic/791797-first-build/#findComment-9972966
**EDIT***
(I'm stupid)
What are you using the pc for ?
An M.2 NVMe SSD isn't needed if you are just gaming.
https://linustechtips.com/topic/791797-first-build/#findComment-9973023
9 minutes ago, EliteLastOne said:
Yes I was. I was looking at the Samsung U28E590D
How about something like this ?
The monitor is a 1440p 165Hz G-Sync IPS. Also as you are doing some streaming the R7 1700 will help as it is an 8 core cpu.
No SLI support but you will be fine with a single gpu at 1440p.
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($299.44 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($40.66 @ Newegg Marketplace)
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  ($108.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($112.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($107.88 @ OutletPC)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($88.95 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  ($683.99 @ SuperBiiz)
Case: Cooler Master - MasterCase Pro 5 ATX Mid Tower Case  ($108.83 @ Amazon)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Monitor: AOC - AG271QG 27.0" 2560x1440 165Hz Monitor  ($625.99 @ B&H)
Total: $2347.60
Generated by PCPartPicker 2017-06-11 13:30 EDT-0400
https://linustechtips.com/topic/791797-first-build/#findComment-9973330
Total: $2347.60
I'll check it out and do my research. Thank you for the advice, I really appreciate it!
https://linustechtips.com/topic/791797-first-build/#findComment-9973528
