Okay, this morning i opened up my gtx750ti to replace the thermal paste and i had run out of isopropyl alcohol, so as stupid as i am i decided to use mouthwash (which contained alcohol) and it worked. i cleaned the heatsink with ease, and then when i tried the video card, a little dripped on the acctual body and i dabbed it off. i then put it in my pc, after waiting 30mins to see static distortion on the screen and my resolution has been permanently set to 800-600. 4 hours after the insident the computer allows me to log in and now in the device menu my gpu has a yellow exclamation mark saying, "windows has found a problem with this device."
so now i believe i am currently using my integrated graphics and not my actual gpu. HELP PLZ
specs:
amd 860k
gtx 750ti
8gb ram
https://linustechtips.com/topic/791549-i-need-help/
specs:
amd 860k
gtx 750ti
8gb ram
try to put real alcohol over it and let it soak. then pack it in rice. then blow dry it for a bit, then try
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/791549-i-need-help/#findComment-9970202
