My brother just got AMD A10 7850k  and A88X-Pro motherboard.
While I was installing his motherboard I figured out that he has no 8 pin CPU Power Connector, only 1x4 PIn,
http://www.game-debate.com/psu/index.php?ps_id=690&psu=MS Industrial Platinum MS-400ATX PSU
https://www.asus.com/Motherboards/A88XPRO/specifications/ MB
I searched online people were saying it can be used 4 pin connector on 8 pin power connector but I don't want to risk frying something.
Only solution I suppose is getting new power supply.
Any suggestions on which one should I get that's not ultra expensive but quality so it doesn't fry my board.
Thanks
Challenger Tier at League of Legends since Season 5.
https://linustechtips.com/topic/790940-power-supply/
16 minutes ago, tiggar47 said:
These are Modular power suplies above 80$
One of those is semi-modular (the CXM) and none are very expensive, let alone anywhere close to $80 USD.
You can use just the 4-pin BTW. The extra +4 pins are for redundancy which don't matter to you
https://linustechtips.com/topic/790940-power-supply/#findComment-9963755
Will those 4 pins deliver enough power for the CPU to work properly even at higher voltage?
https://linustechtips.com/topic/790940-power-supply/#findComment-9963759
Yes. That's why H81 motherboards that support the 4790K and its turbo speeds work just fine with just four pins.
https://linustechtips.com/topic/790940-power-supply/#findComment-9963797
