Game settings help??
Go to solution Solved by That_PC_Kid,
The higher the setting and resolution the higher the workload on both the CPU and GPU but most of the workload is placed on the GPU.
Hello there!
I have a Core 2 Duo machine (E7500 OC @3.35ghz) paired with a GTX 970. Basically, my new motherboard for my new CPU is taking some time to deliver. So, I am stuck with this for the moment.
I was thinking of playing GTA V and was thinking what settings to play on.
I have two displays, one is 1920x1080 @ 60HZ and the other is 1280x800 @ 75HZ.
Is choosing any make it more cpu dependent?
I am also confused on how game settings work.
If i choose low settings, lets say cpu workload is x and gpu workload is y.
If i choose high settings, will cpu workload stay at x and gpu workload increase from y or does cpu workload also increase?
GTA V is a terrible game for this type of setup as it is more CPU dependent, i know.
Thanks for taking the time to read!
https://linustechtips.com/topic/790887-game-settings-help/
