4 minutes ago, kb5zue said:
Don't know what it could be, or what it will be, or what it should be, but given the equipment listed it won't matter.
The human eye can't really tell the difference between 60 fps and 120 fps anyways.
i want to know if it will go more than 60 fps on max settings
https://linustechtips.com/topic/790407-help/#findComment-9957366
Just now, JJVGaming said:
the bottom one is a 1050 ti, and typically a 1050 performs 10 to 20 percent less than a 1050 ti, so we can say maybe if you put at all high settings with fxaa u wil get 60+ no problem
sounds good to me bcz right now my specs are i5 3400 or somthing like that and proccesor video card .... so yeah i cant even play csgo :)
https://linustechtips.com/topic/790407-help/#findComment-9957384
5 minutes ago, Daivon said:
2200 RON, 5 RON is 1 euro like 450 euro i think
2200 RON = 481 Euro
This is what I would've suggested, It's 7 euro over the budget but here you go.
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  (€64.89 @ Mindfactory)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard  (€71.42 @ Amazon Deutschland)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€50.00 @ Amazon Deutschland)
Video Card: Zotac - GeForce GTX 1060 3GB 3GB Mini Video Card  (€197.21 @ Mindfactory)
Case: BitFenix - Comrade ATX Mid Tower Case  (€39.90 @ Caseking)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply  (€64.89 @ Amazon Deutschland)
Total: €488.31
Generated by PCPartPicker 2017-06-08 11:35 CEST+0200
https://linustechtips.com/topic/790407-help/#findComment-9957420
Not too bad, maybe around ~70 fps at high-very high.
Going to assume that is a joke.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/790407-help/#findComment-9957437
No, it is NOT a joke.  I was dead serious.  I read as many of these forum posts as I can and I read the spec sheets on as many video cards as I can because that is what I do.  I'm an electronics technician and have been for the past forty plus years.  Reading and watching all the information I can while I am still able helps me keep up to date with the industry and what is going on.  Basically, helps keep me young.  I'm 62.
I think it's funny that some people just have to have the latest and greatest, especially when it comes to video cards. Got to have that 280 frames per second, etc....  think about it, the computer is changing the pixels (picture) on the screen x number of times PER SECOND.  The human eye can not tell the difference.  It can't "see" the changes being made that fast.  So, if you thought my comment was funny, that's okay.  Just chalk it up to experience.
https://linustechtips.com/topic/790407-help/#findComment-9957458
Funny that I can see a noticable difference between 60 and 144hz then....
There has also been done some blind tests and everyone could see the difference between 60 and 120 hz.
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
https://linustechtips.com/topic/790407-help/#findComment-9957505
11 hours ago, kb5zue said:
good for them.  So if you can see the difference, would you mind telling me what is going on when the speed hits 112fps?  For some reason I just can't get that one right.  I guess that is why they call it the sweet spot.
with a 60hz monitor, you're right.  but with a 120hz monitor, you're wrong.   if the screen is refreshing 120 times per second, you will see a very clear difference between 60 and 120fps.
with your logic, theres no difference between 45 and 60 fps.
studies have shown that the human eye can respond to signals in less than 1ms, which can correspond to about 1000 "frames per second". which means theoretically we can notice upwards of 1000fps or more.(although the human eye does not actually see in fps). however until we start seeing a monitor with refresh rates that high, it doesnt matter
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/790407-help/#findComment-9960642
