Minecraft server does not work.
Go to solution Solved by Agris,
Fuck this I give up on getting this to work
Hey
So basically I made a server using this video
I did everything right but .. When I join from my local IP address it works, but when from my public address it does not shows this:"java.net.ConnectException: Connection refused: no further information"
What should I do? I've even set "online-mode:false" so the server does not check if the Minecraft is legit. What the hell do I do to make this work?
https://linustechtips.com/topic/789108-minecraft-server-does-not-work/
Enable external connections to have access to the particular port of the server through the router and firewall maybe? I'm not sure.
Desktop benching:
1 minute ago, Agris said:
HUAWEI-E5186-22A
This link should have all the information you will need:
https://portforward.com/huawei/e5186s-22a/
I wouldn't use their software though, follow the guide :)
I will only ever answer to the best of my ability - there is absolutely no promises that I will be correct. Or helpful. At all.
My toaster:
CPU: Intel Core i5-4670k @ 4.3GHz
Motherboard: Asus Maximus VI Formula
RAM: 16GB Corsair Vengeance DDR3
GPU: Nvidia GeForce GTX770 2GB
Case: Some free Sharkoon case
Storage: Crucial MX500 500GB SSD | Western Digital Blue 1TB
PSU: Corsair HX750
Display(s): Acer framless 24" 1080p thing | Acer 22" 1600x900 thing
Cooling: Corsair H100i AIO | 2 x Corsair LL120 front intakes on radiator | 1 x Corsair LL120 rear exhaust
Keyboard: Steelseries Apex
Mouse: R.A.T 7
Sound: HyperX Cloud II headset | Creative EAX 5.1 speakers
OS: Windows 10 Pro
4 minutes ago, Agris said:
Do I enter in my local or public ip?
Where? Do you have a screenshot of what you have so far?
My toaster:
PSU: Corsair HX750
Mouse: R.A.T 7
OS: Windows 10 Pro
Just now, Agris said:
I had done this earlier but still did not work that's why I made this post
How had you tested it to check that it didn't work?
My toaster:
PSU: Corsair HX750
Mouse: R.A.T 7
OS: Windows 10 Pro
I asked my friend to join the server, I have him my public IP address and said him to put it in the direct connect and connect and it did not work.
Is he connecting to the correct port? What error message did he get?
My toaster:
PSU: Corsair HX750
Mouse: R.A.T 7
OS: Windows 10 Pro
