My brother is upgrading to a 1080 ti from a 1080 and he's giving me his old card. Before he does that I'm upgrading my CPU from the i3 6100, but I can't decide which to buy.
It's between the 7500 and 7700. I'm not paying for any unlocked processors, I don't have an overclocking board and I can't afford to buy a new one.
I know the 7500 would bottleneck a little, but I don't know if it's worth it to spend the extra $100 to get an i7 and avoid the bottleneck.
https://linustechtips.com/topic/788982-best-cpu-for-a-1080/
If you're playing at 1440p or below, it's definitely worth it. you'll really bottleneck a 1080 with an i5.
if you want, for the same price as a 7700, you can go with a Ryzen 1600. it's not quite as good for average FPS, but it's comparable, and sometimes better for min FPS.
in this scenario, it's not a clear-cut choice to get Ryzen, but it's still an option.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/788982-best-cpu-for-a-1080/#findComment-9940156
Would it also be a reasonable option to buy an i5 now and grab a 4k monitor later?
https://linustechtips.com/topic/788982-best-cpu-for-a-1080/#findComment-9940171
Kinda.
an i5 wouldn't bottleneck a GTX 1080 with a 4K monitor, but it's still a bad idea.
Just get the i7
Laptop:
https://linustechtips.com/topic/788982-best-cpu-for-a-1080/#findComment-9940189
1 minute ago, Harshil1996 said:
Always buy i7. I upgraded from i5 6600k to 6700k because it was maxing out already in the witcher 3. But with i7 everything is smooth. Consider getting an 6700 as its getting cheaper. And will surely be staying cooler than an 7700.
Temps really don't matter on locked CPUs unless it's danger level.
It might be warm. upper 70s or low 80s, but that's still not dangerous.
Laptop:
https://linustechtips.com/topic/788982-best-cpu-for-a-1080/#findComment-9940194
It'd be worth the extra to grab the i7-7700 instead of the i5-7500. Four cores and four threads only gets you so far.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/788982-best-cpu-for-a-1080/#findComment-9940196
