I need a software solution for controlling fan speed on my server. There's no option for fan control in the BIOS, I guess because it's an Asus H81 board with a very basic BIOS. I tried Speedfan within Windows but I couldn't get it to detect any fans. I can't find any other options anywhere. Do any more exist?
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/788879-fan-control-software/
If speedfan doesn't work then your motherboard probably has no fan control hardware built into it, or at least none that interfaces with software.
Buy a fan controller.
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9938922
My board came with AI Suite, does your have the option or did it come with some kind of "extras" software like AI Suite?
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9938925
The board's originally from a prebuilt so... probably not?
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9938993
Just now, NCIX Lampy said:
Which OS? It has a UEFI BIOS and from looking at Asus's page it looks like it comes with AI Suite, could be wrong.
Win10, guess I could just download AI Suite and it would recognize it then?
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939372
https://www.asus.com/us/Motherboards/H81ME/HelpDesk_Download/
Go to Utilities and then scroll down to AI Suite 3
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939383
Ugh okay do you remember which installer you used? There are two different downloads that say AI Suite and in each folder when I download them there are like 8 different setup.exe files in different places, I can't get anything to work.
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939632
In the folder "Win10" > "AISuite3_1.01.05" > "AppSetup" > "Setup"
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939717
I think I tried that one and it didn't seem to do anything but I'll try again
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939957
Try restarting your PC and then try again, if that doesn't work, maybe it's already installed or something. If not after that, then I would contact Asus live chat support, they'll be able to help you for sure.
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939963
Yeah when I try that it pulls up a loading bar that says something something DIGI+VRM something something (can't read it cause it disappears almost instantly) then nothing.
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939964
Did you try "Setup" and "AsusSetup"?
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9939999
Yep, after clicking yes on "do you want to allow this app to make changes" they both just don't do anything.
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9940011
Restarting your PC didn't do anything either?
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9940015
This isn't THAT important so I may just give up for now tbh unless you can think of something else to try :D
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9940051
I would definitely contact Asus's live chat support at that point. I've never had that issue.
Haha yeah I may, that's my luck for ya. Something simple that everyone can do like literally downloading and installing a program? Nope, doesn't work.
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9940071
There is one other thing you could try, but you won't like it very much. And even then, I would still contact Asus's live chat support and tell them to get their heads out of their asses for such a basic issue. I would've been pissed.
https://linustechtips.com/topic/788879-fan-control-software/#findComment-9940090
