What resolution if 1440p get the 6gb and a single fan is quite noisey try to get a dual fan but pretty solid
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/787651-thoughts-on-build/#findComment-9923786
Just now, HopTrain said:
1080p
Then the gpu is fine only thing I would change is the cooler type because people do say that single fans are noisy but if noise doesn't bother you it's fine
https://linustechtips.com/topic/787651-thoughts-on-build/#findComment-9923793
1 minute ago, HopTrain said:
also i plan to play on low to medium graphics will the fan still be loud?
Yeah but are you goo g to be using a headset or speakers
https://linustechtips.com/topic/787651-thoughts-on-build/#findComment-9923797
headset 70% of the time
Ok then the noise shouldn't bother you
https://linustechtips.com/topic/787651-thoughts-on-build/#findComment-9923804
-get Ryzen 5 instead
-get a 580 4gb instead, 1060 3gb isn't very good
Is your budget $700? I can make a list for you.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/787651-thoughts-on-build/#findComment-9923832
Only $15 more, and you get a 1600+580 instead (much better)
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($215.98 @ PCM)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($83.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($54.88 @ OutletPC)
Storage: PNY - CS1311 120GB 2.5" Solid State Drive  ($52.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Sapphire - Radeon RX 580 4GB PULSE Video Card  ($206.99 @ SuperBiiz)
Case: Xion - XON-350_BK ATX Mid Tower Case  ($22.98 @ Newegg)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $713.23
Generated by PCPartPicker 2017-06-01 22:33 EDT-0400
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/787651-thoughts-on-build/#findComment-9923889
