Yeah.
if you're using a powered hub though, it will run at 100% speed. if you're using an extention from a 4-pin mobo header, or something that supports a 3-pin fan, then you will have fan control.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/786753-pwm-cable-question/#findComment-9913234
9 hours ago, Delta. said:
3-pin PWM cables
What now? The 4th pin is usually what carries the pwm signal.
https://linustechtips.com/topic/786753-pwm-cable-question/#findComment-9915140
