first pc need help.
Go to solution Solved by Lucakro,
1 minute ago, grimreeper132 said:
Things it supports
SLI
Crossfire
RAID
overclocking
good sound shit
wifi (which is great to have built into to a motherboard and quite rare (at the moment) for Ryzen)
high frequency RAM (which again is great for ryzen)
1xUSB 3.1 type A
1xUSB 3.1 type C
RGB headers
some fancy PCI-e CPU thingy which is meant to help with overclocking
Bluetooth
it has alot
thats pretty damn nice yess which motherboard was that the ASrock ?
Vergeet niet om anderen te @namen. Anders krijgen ze geen melding, en kijken ze hier niet meer naar...
On topic: Some of the more expencive coolers will do a better job at cooling then lower end and even some mid range closed loop water coolers. So if you spend the money, you should be able to do some overclocking on an air cooler.
5 minutes ago, Lucakro said:
thanks
okay say i could shell out another 100 for the motherboard making it 200 for just a motherboard which one would be the best with all the others
and small components i dont mind replacing after a year or so it's really just the bigger ones i wanted to avoid.
had an issue with the storage didn't notice it didn't have a price so builds more expensive than expected, so things were changed, so now 30 over the 1600 (due to your adjusted budget) Better motherboard, (better chipset etc.)
https://de.pcpartpicker.com/list/NNRBpb
there is also no water now though, which as you said isn't a problem a 212 evo you still could get a good overclock with.
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
put in 212 evo, far as I know they are good air coolers. Mainly because I noticed I had an issue with storage
Just now, Lucakro said:
okay but that would a big fan no ? would it still fit in the case
no clearance issues are being flagged so yes it would, and it's a big enough fan yes. it's a 120mm fan I think so it's quite big
okay i have one kinda dumb question i think why does the SSD look so weird and it does give me a issue with the motherboard and bandwith ? what does that mean
By weird im guessing you mean no shell/covering on it? Its an m.2 ssd so you plug it directly into the motherboard, no room for a shell.
okay but what does motherboard shares bandwith SATA mean ?
"When the M.2 slot is populated, one SATA 6Gb/s port is disabled."
Basically means that it makes one of the sata 6 ports turn off so the M.2 slot can work.
does it affect anything ? in preformance or ...
and where do i get the solution to this
  • The Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler may require a separately available mounting adapter to fit the Gigabyte - GA-AX370-Gaming K3 ATX AM4 Motherboard.
@grimreeper132how do i solve this is it included in the fan
sorry I went to bed, you would need to order the bracket off cooler masters website
http://www.coolermaster.com/amd-am4-ryzen-compatability/en/
they would be only 3 euro max probably
@grimreeper132
thanks this settles everything for now. i'm gonna put a list together of all the other things keyboard etc. if you could be so kind as to look at it when i'm done and check what i've compiled i'd appreciate that a lot.
@grimreeper132
it's alright just ping me when your done and I will. Glad I could help.
Heads up if you quote you don't need to ping.
1 minute ago, Lucakro said:
@grimreeper132
sorry i just thought of something why woould mechanical keyboard need to be so loud ?
Sorry???
are you asking why people like loud mech keyboards??? simple cause it sounds cool I guess and some people like the noise. Also mech keyboards feel so much better than non-mechs when you are typing on them for a long period of time so that as well.
Just now, grimreeper132 said:
Sorry???
yeah yeah the physical typing aspect i get but is there also an option of silence ?
Sorry???
yea some switches are silent so some people like the noise
okay thanks can you buy a keyboard with speed switches and put silent switches in it yourself ?
don't think so, you normally buy the keyboard with the switches you want
@grimreeper132 , @Dutch-stoner , @RKRiley
Hello back again.
i think i'm almost done i hope at least cause i'm not just over what i wanted to spend originally. i've upgraded the motherboard and removed the 1TB hdd as i have some spare ones. I do hope some of these parts will be available second hand but i also don't mind spending a bit extra as it futureproves ( thanks for bringing that to my attention dutchstoner i hadn't really thought it through.)
https://de.pcpartpicker.com/user/Lucakro/saved/2xggsY
i've a few doubts about the monitor the wireless card ( and how it will look in a windowed case next to the GPU whose appearence i do like ) and the case ( does it come with the fans from the picture because in says it has empty bays so what does that mean then ? ) if you have any concerns at all even something like RGB interface just tell me please i dont want to walk into trouble after i've bought. keep in mind i'm far from an expert.
anyway hope this is my last post and thanks to all of you.
Lucakro
Hello back again.
Lucakro
also would i be able to use SLI ? i researched it and i think it would be nice way down the line when it starts to show age.
