Hey, i decided to build a pc but im not so good at chosing the parts for it so i ask for help.
Could you plz save the wishlist on this website ( www.pcgarage.com ) ? you go on your cart in top right corner save as wishlist (in my country language).
BUGET 450E that means anywhere between 2000 RON -2400RON
THX
https://linustechtips.com/topic/785737-help/
So where do you live?
If there is a place with better deals might as well go there.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/785737-help/#findComment-9901639
He means www.pcgarage.ro
CPU: AMD Ryzen 9 5900X 12; GPU: GeForce RTX 3080 Gigabyte Vision OC V2 10GB; PSU: EVGA 750W 80+ Gold Certified; RAM: 4x32GB (w/RGB xd); SSD: 1xM.2 Samsung 980 Pro 1TB, 1xM.2 Samsung 970 Pro 1TB, 1xWD 6TB HDD; OS: 10; Monitor: 1xAorus IPS 27" (2560x1400) 1xBenq IPS 32" 4kKeyboard: Corsair K95; Mouse: Logitech G Pro X Superlight w/ Steelseries QcK mousepad.
Laptop - HP Omen 15" w/5800U, GPU 3070, 1TB M.2 WD Black, 2TB M.2 Samsung 980 Pro, 64GB RAM.
https://linustechtips.com/topic/785737-help/#findComment-9901652
2 minutes ago, Daivon said:
i live in romanian . as i know this is the better site :/
Give me 5min
https://linustechtips.com/topic/785737-help/#findComment-9901656
http://www.pcgarage.ro/vizualizare-wishlist/2682066/
Went just slightly over your budget but really didn't want to compromise more, you could buy most of these and leave ram for last which you'd buy by the time you put this together.
https://linustechtips.com/topic/785737-help/#findComment-9901790
I would rather get G4560 and save the money to get a better GPU and PSU
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/785737-help/#findComment-9903535
thx it looks grate but its over my buget :/
https://linustechtips.com/topic/785737-help/#findComment-9903711
  • 3 weeks later...
If you habe not decided yet,  I'll give it another go for less.
https://linustechtips.com/topic/785737-help/#findComment-9995366
