Hi everyone!
This is my first time posting here so sorry if i miss something.Im having problems with my pc which consists of
-Core 2 quad Q8200-overclocked to 3.0ghz
-8gb of ddr2 ram
-RX 460 2gb from sapphire
-Gigabyte p35 d3sl (1.0)
-Antec VP500 (500w) psu
-3 HDD
and 2 case fans
The problem I'm having is when I'm playing games they will randomly crash and the only successful solution I've found is to downclock my card and reduce the power limit,but that reduces my performance.I have tried running it without the overclock,taking out HDD and fans,but the problem still doesn't go away.
Sorry for my english it's not my first language.
https://linustechtips.com/topic/785649-problems-with-my-rx-460/
IMO it's the PSU problem
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900595
1 minute ago, Duksaaa said:
The PSU is brand new I just bought it thinking it would solve the issue.
But it has bad quality
Desktop specs:
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900609
Unlock voltage monitoring in MSI Afterburner for more info.
I don't think it's significant enough to cause crashes. His parts won't consume more than 300W of power, 60% or the rated value. Even a badly made PSU should handle <60% load
Desktop benching:
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900635
5 minutes ago, Duksaaa said:
Not really I've looked at a lot of reviews before buying it and they all agree that this is a good quality psu.
@STRMfrmXMN @Energycore
It's really bad in terms of quality, let PSU gurus explain
Desktop specs:
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900652
A crap PSU may not be able to deliver enough wattage even it's 60%
Desktop specs:
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900657
The VP500 isn't terrible enough for me to think it's the problem. My guess is that the card is factory overclocked and he's playing games that don't allow for overclocking. I have a friend with a Kingpin 980 Ti and all the time Overwatch will crash itself deliberately because the factory clocks of the Kingpin are so far above reference clock that Blizzard doesn't trust it, even though it's stable from the factory at those speeds.
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900672
Reviews on websites like amazon aren't a reliable. The corsair VS 650W is a bad power supply but it still has a 4 star rating on amazon with more then 100 reviews.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900687
While it does look like the psu might be the problem his rig is literally sipping power...
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900699
@Mr_Random_Guy the rx 460 doesn't require external power and the cpu has a 95 watt TDP so that shouldn't be an issue.
But you are having an issue, you wouldn't be here in first place if you don't have a problem.
I'm just trying to eliminate the real problems
If swapping PSU can fix the problem then good, but since you are out of option to RMA the card (I hate store who do that stuff)
The other option is to test your card with different computer (or motherboard according to you anyway)
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900731
That's what I was saying, the fact decreasing your power limit works points towards the PSU, but you are literally pulling such little power its unlikely.
That being said I used to have a no name 500 watt PSU and when I installed an RX 460 it blew up under load
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900734
The thing is when I decrease the power limit and leave the core and the memory at stock it still crashes,but when I downclock them by 200-300mhz the system is stable and I can play games like the Witcher 3 or ROTTR with no issues.
That's what am I saying, isn't this so obvious.
You have defective card
Just because it runs at lower speed (lower than default at least) doesn't mean it's okay.
There's definitely something wrong with that gpu.
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900761
Hmm, so that's my theory about you playing Blizzard games out the window. Sounds like you bought this PSU recently too.
Can you try running the 460 in another PC?
https://linustechtips.com/topic/785649-problems-with-my-rx-460/#findComment-9900763
