75hz Not Working on Ultrawide Monitor
7 minutes ago, Atreyix said:Make sure in the game you are playing that the resolution the game is set at isn't 60hz, for example in diablo 3 the resolution is 1920x1080x60 ... you gotta change it too 1920x1080x75 from the drop down. Also some games also have a setting to have the max framerate cap at 60 and you can change it to w/e you want.
11 minutes ago, ARikozuM said:Maybe Freesync is blocking it? All I have are conspiracy theories.
12 minutes ago, mebaby2 said:Sry posted at like the same time together HDMI 1.4b supports higher refresh rates at 1080p.
Like I said before make sure freesync is turned on on the monitor itself.
And it's set to 75hz under advanced settings in windows itself or it won't show up in games.
It worked for me but seeing I have 1 nvidea using PC I can't check if it always works.
16 minutes ago, Princess Cadence said:
19 minutes ago, Glenwing said:From what I've read in the past, you really do need to use FreeSync to get the 75 Hz, custom resolutions won't work. No idea why, but that's how it is. So I hear, anyway.
I figured it out, disabling Freesync allowed games to show 75hz as an option
