Ok so am trying to set up a a new computer build and so far everything on my list seems to be ok , but i am having a compatibility issue with the motherbored and cpu cooler
heres the link to the list https://pcpartpicker.com/list/Yb4rsJ
and here are the two parts in question https://pcpartpicker.com/product/xn8H99/nzxt-kraken-x52-liquid-cpu-cooler-rl-krx52-01
https://pcpartpicker.com/product/LgmxFT/asrock-x370-killer-sliac-atx-am4-motherboard-x370-killer-sliac
is there any way to fix it, or buy an adapter for it? or will i just need to buy a different cooler
https://linustechtips.com/topic/785152-compatibility-problems/
you need to contact nzxt if they sell an AM4 mounting bracket or if you can order one when you bought a cpu cooler of them
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/785152-compatibility-problems/#findComment-9895484
i just was curious and checked out corsairs hi100 v2 also will have compatibility issues says pc part picker
https://linustechtips.com/topic/785152-compatibility-problems/#findComment-9895517
