Monitor Artifacting
Dannytheninja
Hello, I have never had a 144hz monitor or a 1440p monitor, but I got me a girl that could do both. Straight out of the box, my Dell S2716DG looked fine, until I turned it to 144hz. Now I have artifacting at random places, I turned off my graphics overclock, with no results. Also the "1ms" response time has to be false even when I changed it to fast in the OSD, I noticed this while scrolling on a webpage. What can I do to fix the response times and the artifacting?
System specs?
And V-Sync is enabled?
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Are you sure the artifacts are not caused by you changing the Overdrive in the OSD to fast? Very few monitors actually can handle that without artifacts.
5 minutes ago, Zando Bob said:
System specs?
V-sync off, monitor is gsync.
Specs:
Core i7 4790k
16gb quad channel ddr3
GTX 1070 Strix
Samsung 850 evo (SATA0
I've tried turning the (GTG) response time down in the osd, and it helps the issue with ghosting, but that confuses the hell out of me
Just now, Dannytheninja said:
-snip-
Got a good quality cable? I assume G-Sync is on. Reset the monitor settings? Or you could RMA the monitor, as it's brand new.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
I have a Monster display-port cable, its a bit older, but I wasn't sure if I needed a DP 1.4 cable or if those were just BS.
I'd try a newer DP cable.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Thank you for your help, but this is a picture of what I am talking about, I don't know much about monitors.
I think that might do it, at 60hz, everything looks fine, but 144hz might be too much to push through the cable. I appreciate your speedy response.
