A Little Budget problem
Go to solution Solved by Guest,
Yes for games you listed even a $500 US computer can do here in US or Canada so converted back to where you live should be more or less $600-700
So get a PC. Much better.
So, i got this problem here...
I am going to buy a phone and a computer pretty soon, and my budget is around 1280$-ish (or Rp.15.000.000,00 if you're indonesian like me)
the problem is that i really want this phone, Xiaomi Mi Mix. and it cost about 40%-ish of my budget (540$ (Rp.7.200.000.00)) so in theory my budget for a computer would be 740$. would that be enough for a decent computer that can run games on 1080p like 60fps (ill play mostly esports game like csgo, dota. and other games like planet coaster, sims4, etc)
so yeah. plz help me
Note : monitor and other peripherals is not included on the budget. js
https://linustechtips.com/topic/784805-a-little-budget-problem/
Ok dude, Thanks!
Note: i am getting both phone and the computer lol
Note 2: an gtx 1060 3gb is around 260$ here
https://linustechtips.com/topic/784805-a-little-budget-problem/#findComment-9891442
13 minutes ago, InVaderTech said:
Ok dude, Thanks!
gtx 1060 3gb isn't very good deal, better go with rx 480/580 4gb or gtx 1060 6gb. Yeah, for esports games 3gb will be enough, but if you're going to play triple-a titles, it's not ideal.
For cpu you can go with ryzen 1600 or even 1700, no need to go further. And yeah, you might not get significantly better performance than core i5 in that kind of games, but for streaming and rendering it much better.
https://linustechtips.com/topic/784805-a-little-budget-problem/#findComment-9891478
Yo i forgot to say that i do need to rendering and streaming.
yeah ill get the 6gigs version no probs, but is 1500x enough for games? or 1600/1700 is minimum?
https://linustechtips.com/topic/784805-a-little-budget-problem/#findComment-9891757
https://linustechtips.com/topic/784805-a-little-budget-problem/#findComment-9891759
I would recommend the 1600 since the price difference between it and the 1500X isn't that big (at least where I live).
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/784805-a-little-budget-problem/#findComment-9891926
