1 minute ago, mok said:
no you dont need to remove it
the heat issue only exists when people read and write gigabytes of data constantly - very high usage
for general use like running your OS and games it will be fine
Agree. If you're going to be doing masses of file transfers, like LTT does for their videos back and forth from their server, then you'd have heat issues. That (and the speed) is most likely why they use NVME PCIe SSDs. That and the fact that Linus loves overkill.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/784558-samsung-960-pro-ssd/#findComment-9888049
7 minutes ago, naeem.ahmadi said:
hi everyone...
should i remove the sticker on the samsung 960 pro before i use it?
it seems to block the heat dissipation since it covers all the pcb
sorry this question may sounds a bit dumb but i havent used one yet
dont remove it, the speed of the drive will decrease
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/784558-samsung-960-pro-ssd/#findComment-9888052
So that M.2 can be installed inside PCIe Body?
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/784558-samsung-960-pro-ssd/#findComment-9888846
Nope. They use the 1.2TB Intel ones that are $500+ and take up an actual PCIe slot, just like a GPU.
Mouse: EVGA X17
https://linustechtips.com/topic/784558-samsung-960-pro-ssd/#findComment-9888900
SSD on SATA=dude where are you gonna put that little thing?
SSD on M.2=dude you just wasted a pointless slot
SSD on PCIe=you should've paid for GTX 1070/1080. And you wasted an important slot!
My head on 2019 :
https://linustechtips.com/topic/784558-samsung-960-pro-ssd/#findComment-9888922
