I know the Ryzen 7 1700 comes with a cooler, that I'll probably use for a while, but if I decide to upgrade later for better cooling, are there any coolers that COME with AM4 brackets? I don't want to have to wait 2 weeks for somebody to send me one *cough* nzxt.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/783927-ryzen-7-cooler/
I think pretty much all coolers have been updated for AM4, just check the descriptions of the item of the cooler or contact support. Nobody is going to give you a free cooler with nothing in return.
Magical Pineapples
https://linustechtips.com/topic/783927-ryzen-7-cooler/#findComment-9880880
Dark Rock 3.
That's what I bought. Sadly my retailer still had old batches, so I got the one without AM4 mounting kit. Contacted be Quiet! company and I got mounting kit in 3 days.
You can also send copy of your bill for your motherboard, and send it to be Quiet. They will ship mounting kit right away, and at the same time you order dark rock 3 from shop. It's most likely that you will receive mounting kit before cooler itself xD
And I'm very happy with this cooler. 1,35V at 3,825GHz ... while gaming it doesn't go higher than 50°C. At idle around 37-45°C (kind high idle temps because CPU is always working on 1,35V and max frequency ... can't make it drop down at idle for some reason).
With stress testing aida64 cpu+fpu+cache, max temp that I saw was 74°C and that was after hours or it. I could drop down those temps by turning my fan higher, but no need for that.
It's dead quiet on idle/gaming. When stress testing, you can barely hear it when 50cm away.
And that's comming from someone who can hear grass growing.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/783927-ryzen-7-cooler/#findComment-9880886
https://www.newegg.com/Product/Product.aspx?Item=N82E16835106372
I use it and its freakin amazing... arguably better than a 212 evo even though its the exact same thing....
derp
https://linustechtips.com/topic/783927-ryzen-7-cooler/#findComment-9881014
