I currently have my entire pc build planned out, with a gtx 1070. I currently have a 1080p 75hz monitor, and I am not going to upgrade it. I really would like a 1600x, but gaming performance at higher refresh rates are not great compared to intel, however ryzen seems to have higher 0.1 and 1% low framerates. Basically which cpu is the best choice, a i5 7600k (overclocked) or a 1600x (also overclocked).
https://linustechtips.com/topic/783852-best-cpu-for-my-needs/
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/783852-best-cpu-for-my-needs/#findComment-9879848
get a 1600 - the 1600x doesn't offer any difference besides an X and a higher clock speed, and they all overclock to either 3.9 or 4Ghz.
i5s and R5s are around the same speed mostly, the i5 pulls ahead in games from 2011-2014, whereas the R5 pulls ahead in more modern multithreaded games.
and then:
idk
https://linustechtips.com/topic/783852-best-cpu-for-my-needs/#findComment-9879905
4 minutes ago, aisle9 said:
did u just make this lmao
Faith: WIP
Cpu: intel 6700k
RAM: g.skill ripjaw v 3200mhz 16 18 18 38 2n 32gb 4x8gb
MB: Asrock extreme 7+
GPU: GTX 1080 TI Poseidon Platinum Asus ROG
PSU: Cougar 1050W 80+ gold
Case: IN WIN 509 ROG [ black red ]
Cooling: Barrow Fittings, Block, 360mm x 60mm rad, 18w d5 pump, 210 res, EK blood red premix. Poseidon GPU block
SETUP: BenQ 27" 144hz|BenQ 28" 1080p VA 60HZ|Corsair Strafe RGB|Razer DeathAdDer Chroma|ATH IM70|E10k Olympus 2 amp|DX Racer King
https://linustechtips.com/topic/783852-best-cpu-for-my-needs/#findComment-9879911
