So for some reason I'm running at lower FPS then i should over watch is about 40 fps, witcher 3 is at 40-45 i feel I'm forgetting something or bottle necking somewhere. they are at max settings at 4k.
16 GB ddr4
ryzen 7 1800x at 4.1Ghz
rog geforce 1070 8gb OC in SLI
crosshair vi hero
1000w PSU
liquid cooled
what am i missing?
https://linustechtips.com/topic/783398-low-fps/
GPU drivers?
Enabled SLI in the nvidia control panel?
Clean installed windows?
Windows updates installed?
https://linustechtips.com/topic/783398-low-fps/#findComment-9874434
turn down the settings. the difference between max and ultra/high is usually pointless things, like super-ultimate-intensive ray tracing, which you won't notice at all. you could also turn off supersampling, since you're playing at 4K
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/783398-low-fps/#findComment-9874574
60 fps seems to be the norm look at your GPU usage
Looking at benchmarks, around 40-45 fps depends on the area 1070 SLI looks to be about right at 4K. The Witcher is an intense game to run a single 1080 gets about 40-50 fps at 4K max and can dip into the 30s.
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
https://linustechtips.com/topic/783398-low-fps/#findComment-9874603
