Does anyone know hoe to remap/configure a RGB header on a MSI motherboard.? I have the z270 m7 with a cablemod led kit, but the green and blue pins are swapped on the header/leds.
Rig Specs: 4690k 4.5ghz, gigabyte gtx 970 g1, Crucial 8gb ddr3, Gigabyte z97x-SLI, Corsair RM750 PSU, 1T WD HHD, 240gb Kingston SSD
Water-cooling Components:EK supremecy CPU waterblock, EK WF3 waterblock, Phantom Balancer 250 reservoir, Topsflo DC pump, Mayhem Dye, Mayhem Tubing, XSPC EX360 radiator
https://linustechtips.com/topic/783259-msi-m7-rgb-header-issue/
@spac3monk you can email support@CableMod.com and we can help you with this directly if you would like. :)
https://linustechtips.com/topic/783259-msi-m7-rgb-header-issue/#findComment-9879042
